ESP CANbus not compiling
Has thanked: 635 times
Been thanked: 842 times
Re: ESP CANbus not compiling
The only thing you should need to do is to use the library updates tool from the help menu. This should give you the latest can driver that should allow internal can to compile.
Dutch
Has thanked: 3 times
Been thanked: 2 times
Post by Dutch »
That i have done (more than ones ;) ) plus clean new install and its showing these versions for ESP (screenshot in attachments).
still compiling with 'can.h" build failed. :cry:
C:\ProgramData\MatrixTSL\FlowcodeV10\CAL\ESP\ESP_CAL_CAN.c:150:10: fatal error: driver/can.h: No such file or directory
150 | #include "driver/can.h"
compilation terminated.
ninja failed with exit code 1
Running ninja in directory C:\FC_ESP\mtxesp32s_sdkconfig\build
Executing "ninja all"...
Build Failed.
C:\ProgramData\MatrixTSL\FlowcodeV10\FCD\ESP\Batch\esp32_build.bat reported error code 0x1
ESP ver.png (154.21 KiB) Viewed 3795 times
Ok that's odd, I've pushed the change to the update system again.
Dutch
Post by Dutch »
BenR wrote:
Wed Oct 01, 2025 3:16 pm
YES! :D 16 updates.
'Build completed sucsessfully' :mrgreen:
Back to creating CAN signals ! i'l test asap.
Thank you Ben.
Regards, Angelo.
