dsPIC30F6014A - C15 pin
Posted: Wed May 31, 2023 1:12 pm
Hi all,
I got a problem with the C15 pin of dsPIC30F6014A controller. In the datasheet, if I'm not wrong, it says C15 pin can be used as I/O applications but I can not use this pin as Output pin. I did not try if it can be used as Input. Tried it with different PCBs with same controller dsPIC30f6014A, same result.
Do you guys know anything about it?
Thank you,
Ege
Thank you,
Ege
