dsPIC30F6014A - C15 pin
egearabaci
Has thanked: 3 times
Been thanked: 2 times
Post by egearabaci »
Hi all,
I got a problem with the C15 pin of dsPIC30F6014A controller. In the datasheet, if I'm not wrong, it says C15 pin can be used as I/O applications but I can not use this pin as Output pin. I did not try if it can be used as Input. Tried it with different PCBs with same controller dsPIC30f6014A, same result.
Do you guys know anything about it?
Thank you,
Ege
p.erasmus
Has thanked: 104 times
Been thanked: 88 times
Re: dsPIC30F6014A - C15 pin
Post by p.erasmus »
I havent check the datasheet and it a long time since I last worked with a 6014 but as I recall it could be that pin is a open drain pin so then you need to connect it ot some sort of source ,just check the pin specs again
Has thanked: 539 times
Been thanked: 722 times
It could be down to your configuration settings. Can you post your project file?
egearabaci
I attached the project file. I am just trying to change the C15 pin there is nothing more in code.
C15.fcfx
(25.08 KiB) Downloaded 777 times
p.erasmus
Post by p.erasmus »
Looking at the datasheet C15 is also the CLK0 pin therefore I would expect that you need to run the corrcet settings and Oscilltor to beable to use C15 as an IO pin
just saying
