Hi everyone
I'm trying to make a program with this mcu PIC32MM0064GPL020 , but at the time of compilation it returns the following error:
xc32-gcc.exe: fatal error: selected multilib 'micromips' not installed;C: Program Files (x86) Flowcode Common Compilers x32 bin xc32 - gcc.exe reported error code 255
Another thing I can't disable the code protection from the menu
Attached is the test program that is simply a led that turns on and off
Best Regards
pic32mm compiler problem
Re: pic32mm compiler problem
I've fixed the configuration problem now so that you can change the code protect flag. In fixing the configuration this also seems to have fixed the compilation error.
Let me know how you get on.
Dear Benj
With the new release I managed to compile correctly.
I'm checking the operation of the pins and everything looks OK
In the coming days I will use some components to test the new board and I'll let you know the result.
Thanks again for the quick support
- celebriums
- Has thanked: 71 times
- Been thanked: 33 times
Dear Benj
I hope you are fine and Be careful with the Corona virus.
I don't think the compiler problem has been solved. I was thinking about doing a project with this processor. I think I'm going to give up.
- PowerNoise.fcfx
- (7.09 KiB) Downloaded 228 times
- QMESAR
- Has thanked: 384 times
- Been thanked: 614 times
Hi .
In my opinion it is not an Compiler problem but and definition file error
Regards QMESAR
Regards QMESAR
Many thanks and to you. I'll look into these issues for you and hopefully provide you with a fix. These are new devices for us and there are usually some teething issues with certain peripherals on new devices. Hopefully nothing too major.Dear Benj
