GLCD ILI9341
Alkaline
Has thanked: 42 times
Been thanked: 41 times
GLCD ILI9341
Post by Alkaline »
I have some problems with the ili9341 display and would like to understand if it depends on the single display or it happens to everyone.
I am currently using this display https://www.buydisplay.com/color-2-4-in ... serial-spi
the interface is 8 bit parallel.
In simulation everything is ok while on the hardware I have a rotated and corrupt image.
To eliminate vertical lines I have to set the display area differently by inverting the widht and hight dimensions.
But at that point I have no correlation between the image drawn on the real display and the simulation
With the latest version if I set the rotation on the number 3 I get only the black screen
DD.fcfx
(19.99 KiB) Downloaded 478 times
faveremario
Has thanked: 8 times
Been thanked: 13 times
Re: GLCD ILI9341
Post by faveremario »
Hi Alkaline
I just started experimenting with the ILI9341 (SPI).
Be careful to select the wright component. Do not select the SPI-component when using the 8-bit // interface and vice-verse.
The last image shown is typical for miss-initing the TFT. I suggest to switch XY-dimensions in the component:
H : 320 (in stead of 240)
W : 240 (in stead of 320)
Hope this helps a little.
Alkaline
Re: GLCD ILI9341
Post by Alkaline »
I confirm that if I invert the coordinates the problem disappears
In the last few weeks I have tried the various versions and the one I can use correctly is the n12.
Both in simulation and in hardware the images and numbers are correctly represented.
Performance has improved compared to version 10 especially on STM
In versions after 12 I can't rotate the screen and write numbers or text. In simulation it works but in hardware it does not.
Let me know if it does the same to you even if you use the SPI interface
faveremario
Re: GLCD ILI9341
I do not see what you mean by n10 or n12.... ?
Screen rotation works for me.
My test-environment : PIC18F4455
Alkaline
Re: GLCD ILI9341
Post by Alkaline »
I am referring to the version of the glcd component as photo attached.
The problem of rotation is the following.
For example I set the value 3 to the rotation, I want to write a number the number on the display, the number will not be drawn.
faveremario
Re: GLCD ILI9341
This is what I get....
Component version 2.0
OwenPrice
Re: GLCD ILI9341 + Flowcode 9 + Simulation
Post by OwenPrice »
Flowcode 9 In simulation mode has anybody had the following problem and fixed it?
Flowcode 9 + gLCD_ILI9341 + SetBackgroundColour(0,0,0) = White Background
Also,
Flowcode 9 + gLCD_ILI9341 + SetBackgroundColour(255,255,255) = White Background
Owen
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: GLCD ILI9341
Post by kersing »
Do you actually display anything with that background? Just setting the background does not change the currently displayed information.
― C.S. Lewis
jgu1
Has thanked: 1135 times
Been thanked: 299 times
Re: GLCD ILI9341
Post by jgu1 »
Hi Owen!
I have just made a testprogram in FC9. It work fine for me.
All color 255 = white
All color 0 = Black
Br jorgen
FC9Background.fcfx
(11.92 KiB) Downloaded 401 times
