Hi Guys,
How do I execute a SLEEP instruction in an Attiny13 to make it power down.
Prior to executing the instruction I understand I need to set MCUCR register to 0x30 and can use a C block to do this ... but I am not sure what I need to do next to execute the actual instruction in Flowcode ?
Found reference to using sleep(); but I get a compiler error for this !
Can anyone please help ?
Iain
Activating SLEEP in Attiny13
iain wilkie
- Has thanked: 13 times
- Been thanked: 9 times
mnf
- Has thanked: 70 times
- Been thanked: 440 times
Re: Activating SLEEP in Attiny13
Hi Iain,
Need to (in a C block - before using sleep())
Need to
#include <avr/sleep.h>Martin
iain wilkie
After a bit of investigation found that this worked in a C block
asm ("sleep");
iain
asm ("sleep");
iain
jgu1
- Has thanked: 1135 times
- Been thanked: 299 times
Hi Martin!
I suppose this also is for the Arduino, please, And how do I give it a "
wakeupcall" again?
I have no experience with this feature.
Br Jorgen
Br Jorgen
mnf
See https://microchipdeveloper.com/8avr:avrsleep for a description..
The processor is basically woken by an interrupt or a reset. It can possibly wake itself by generating a wdt (watchdog timer) interrupt..
I posted a 1s flasher using the wdt here viewtopic.php?f=76&t=21832&hilit=wdt which worked well on the Arduino ATMega328 chip but sadly not on the AtMega8 chi
jgu1
