Using the PIC18F45Q10 and the ADC is not working in Hardware.
Simulation is fine inside of flowcode.
I had a similar problem with the ADC on the PIC18F25Q10 part.
Hopefully it is a similar solution.
Thanks,
Dave
PIC18F45Q10 ADC
Re: PIC18F45Q10 ADC
I have not got to trying FVR yet but I see it in the Drop down.
I expect to need a C code block to select the FVR voltage.
For now I am just doing a simple test to check the ADC functionality.
Reference is Vdd, Pin An19
Just reading a slide pot with "GetInt" and displaying the result on a display.
FlowChart attached.
Thanks,
Dave
FlowChart attached.
Thanks,
Dave
- AD_Test.fcfx
- (9.73 KiB) Downloaded 222 times
Re: PIC18F45Q10 ADC
For a reality check I swapped out the PIC18F45Q10 with a PIC18F45K40
and the ADC works correctly including the FVR register.
The Chips are functionally similar so it looks like there is a real issue with the PIC18F45Q10 part.
Thanks,
Dave
Thanks,
Dave
Re: PIC18F45Q10 ADC
Hi Dave,
I'll have a look into this for you today and see if I can work out what the problem is.
Re: PIC18F45Q10 ADC
I've now had a go at making a change that will hopefully allow the ADC to work on the Q10 devices.
Let me know how you get on.
