signed/unsigned int 64 inside FC8
Dirk Bubley
Has thanked: 14 times
Been thanked: 12 times
Post by Dirk Bubley »
Hello FC Team,
ist it possible to create a variable int 64 signed and unsigned inside FC8?
BR
Dirk
Re: signed/unsigned int 64 inside FC8
Yes I beleive it's possible but only via the C code icon or the supplementary code window.
Signed 64-bit variable
signed long long var;
Unsigned 64-bit variable
unsigned long long var;
Hope this helps.
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
You will need to take a close look at the data sheet for the compiler for your particular device to see if it is implemented. Last time I looked the 8 bit PIC devices didn't support 64 bit. However it seems some (all) now do if you use a fairly recent XC8 compiler. My (slightly older) FC8 install uses XC 1.45 which does not support 64 bit yet.
Compilers for other targets might differ...
― C.S. Lewis
kersing wrote:However it seems some (all) now do if you use a fairly recent XC8 compiler.
Just a reminder of this post if not already seen it?
