Pic12F1840 how to change settings durin it run
castabob
Has thanked: 3 times
Been thanked: 1 time
Post by castabob »
Hello Martin,
I ask you for help with an operation that I don't know how to perform.
I am using the PIC12f1840 because I need few I / O and a serial line. The program starts with an initial setting of pins 6 and 7 such as RX and TX and after acquiring some data from a PC (via rs232) I need to set (at this point in the program) these 2 ports as analog inputs (the hardware is ready to do so).
To set the various functions of the chip I use the "2D: Dashboard Panel" and I don't think I can set the functions of pins 7 and 8 both for the rs232 and as analog inputs whose functions I would then call in the program after having finished the work with the rs232.
I would be very grateful if you could give me a suggestion (assuming that what I need it can be done)
castabob
Re: Pic12F1840 how to change settings durin it run
If you call the following code in a C icon after you are finished with the UART then this should disable the UART and put the pins back into the standard IO mode where you can use them as ADC inputs or general purpose IO.
TXSTA = 0;
RCSTA = 0;
If you want the UART functionality again after this simply call the initialise function again.
castabob
Post by castabob »
sorry if I haven't answered before but I had to fix other little things to run the program correctly. After the indication you gave me, everything is working properly now.
I have another problem where the compiler gives me an error (attached file) . Where am I wrong? How can I solve it?
Yours sincerely
castabob
Error.pdf
(47.85 KiB) Downloaded 364 times
Hi Bob,
Can you try
TRISAbits.TRISA5 = 0;
Alternatively you can just have an output and set it to 1 or 0 at the required time.
castabob
Post by castabob »
as you suggest to me "TRISAbits.TRISA5 = 0;" the compilation do not give error.
Before I had tried only writting the instruction: "TRISA5 = 0;" and even so it didn't give me an error ... is it correct even just so?
thank you very much
bob
Hi Bob,
your're welcome.
castabob wrote:Before I had tried only writting the instruction: "TRISA5 = 0;" and even so it didn't give me an error ... is it correct even just so?
That should work equally well.
what I would do is after
TRISA5 = 0;
, is just confirm by connecting a 1Kto 10K resistor from the A5 pin to VDD.
If voltage is 0V then it's worked.
If around VDD, then has not worked.
I believe it will work and should not be an issue.
