Script Syntax Error
stylo
Been thanked: 3 times
Script Syntax Error
Post by stylo »
Syntax error.JPG (24.52 KiB) Viewed 5558 times
Script Syntax Error. 16F1509 running 4 Chan PWM.
Got to a point programming this project where it refused to work. so, scrapped it and started again with the same result, then this popped up on the screen?
Any help gratefully received.
Stylo
4Ch_Light_Engine_16_6_20..fcfx
(21.52 KiB) Downloaded 264 times
LeighM
Has thanked: 481 times
Been thanked: 699 times
Re: Script Syntax Error
Post by LeighM »
Hi Stylo,
That is not an error with your project :D so just click No to remove the popup.
The issue is caused due to problems with our server, which is currently undergoing updates and fixes.
Sorry for the confusion caused, hopefully all will be resolved soon.
stylo
Post by stylo »
Hi Leigh
Thanks for the prompt reply,
I will divert to some of the domestic chores waiting for my attention.
I presume you will let us know when the problem is fixed.
Stylo
Has thanked: 114 times
Been thanked: 422 times
Post by Steve »
That "script error" occurs when Flowcode has a problem trying to contact our website (e.g. when checking for updates). It should not cause a problem with your project, so there must be something else wrong with it.
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
Hi Steve,
Can the check for updates be changed to be done once at program startup and not every time I save a flowchart?
Best regards,
Jac
― C.S. Lewis
Post by Steve »
Hi Jac,
I think the intention is to avoid a large volume of internet traffic where everything is checked, so Flowcode just checks for the currently used objects.
Normally, this shouldn't be a problem and it would be unobtrusive.
The recent problem with our website going down has highlighted that Flowcode throws that error each time it tries (and fails) to get information from the website. I think the real problem is that this error is being reported to the user. Instead, Flowcode should silently detect that the website is unavailable and, for example, show a local version of the welcome page or prevent checks for available updates.
At the same time, I will look into how we can improve how Flowcode communicates with the internet whilst still providing up-to-date information on updates, etc.
Steve.
AbhijitR
Has thanked: 284 times
Been thanked: 80 times
Post by AbhijitR »
Hello! Steve
good afternoon
The Script Error pops every time i try to save the project, i read above post so not worried just want to put to notice.
Abhi
