Timer1 Does not work
Re: Timer1 Does not work
Have you tried this on real hardware or just inside the Proteus sim?
The setup is fairly straightforward and looks to be correct, could it be a Proteus sim problem? If you could try it on real hardware then that might give a much better indication.
Hello Ben
I tried it on real hardware.Unfortunately it did not work.
Also in the interrupt frequency section, interrupt frequency is created from the main source frequency.
And files
Hmm the generated code does look ok, I've just compared it with the datasheet and I cant see any problems.
Can you send us a schematic of your current hardware setup so we can investigate what the problem might be. I tried your Proteus file but it isn't opening in my version.
Have you confirmed the chip is running, using a 1 second flasher test?
You have the configuration setup for an 20MHz external oscillator but this is not supplied on the schematic. First concentrate on this and getting the 1 second flasher running.
Next the crystal across the T1 pins needs capacitors to ground on both of the pins, datasheet specifies 33pf.
Hello Ben
I made the changes you mentioned(In real hardware), but nothing happened again
I acted according to the data sheet
But in interrupt settings, the interrupt frequency changes with clock speed change,That shouldn't be the case
Is the one second flasher test now working? Nothing will work if this isn't working.
https://www.flowcode.co.uk/wiki/index.ph ... ED_flasher
The interrupt properties interrupt frequency is wrong and is not calculated correctly. Its a bug that has been there for a while. It basically cannot know the frequency of your external input and so treats it as off the main clock. This can be ignored and won't cause any problems.
Hello Ben
Thanks for the reply.
The microcontroller works with the one-second flasher you provided,But I want to work with Clock Source 32,768 kHz(T1CKI/T1CKO).
I want to design a watch using the internal RTC microcontroller.
Can't this problem be solved?
Could it be your crystal at fault? Do you have a link to the crystal you are using so we can look at the specifications.
The code Flowcode is producing all looked ok to me but there could be something additional I am missing. I'll have another go through the datasheet just to try and be sure.
There are a few hints here that could help.
https://www.microchip.com/forums/m947335.aspx
I've looked at the code and it looks ok.
Maybe try setting the T1OSO pin (C0) to be an output by writing to the pin using an output icon before enabling the timer interrupt.
Maybe also try writing to the T1CON register yourself inside a c icon after enabling the interrupt to see if this helps.
This should set 1:1 prescale, T1OSCEN enabled, TMR1CS External Clock, Enable Timer1
Maybe also try
Which adds that the external clock sould be synchronised with the internal clock.
If all else fails maybe try a different crystal. The load capacitance/resistance of your crystal could be causing issues on the older 16F873A device.
T1CON = 0x0B;Maybe also try
T1CON = 0x0F;If all else fails maybe try a different crystal. The load capacitance/resistance of your crystal could be causing issues on the older 16F873A device.
- QMESAR
- Has thanked: 384 times
- Been thanked: 614 times
Hi.
Did you probe the XT pins with a scope to see what the XT signal looks like and it drive level???`
if so can you post the scope print !
if not then do it
if not then do it
Regards QMESAR
Regards QMESAR
