send string
Been thanked: 1 time
send string
Post by 0101 »
Hello everybody,
Please, if anyone can write in C the sending of a string, for example "5501A3D2" or any other hexadecimal string. Flowcode generates a C file, but it is too big, it has many program lines.
Thank you in advance !
send string.fcf
(8.5 KiB) Downloaded 2193 times
Re: send string
What do you mean by the file is too big? Compiling with v6 I am getting these stats.
Memory Usage Report
RAM available:368 bytes, used:56 bytes (15.3%), free:312 bytes (84.7%),
Heap size:312 bytes, Heap max single alloc:110 bytes
ROM available:8192 words, used:266 words (3.3%), free:7926 words (96.7%)
0101
Re: send string
Post by 0101 »
Hi Mr. Ben,
I meant that there are many lines of program. I wrote the same program in mikroC, I have to put a button on it. If the file written in mikroC is compared to the file generated by Flowcode you will notice the size of the program.
send string.c
(11.99 KiB) Downloaded 2139 times
MyProject.c
(160 Bytes) Downloaded 2151 times
0101
Re: send string
Post by 0101 »
Maybe someone can help me because it doesn't work.
MyProject_2.c
(202 Bytes) Downloaded 2154 times
0101
Re: send string
Post by 0101 »
Can anyone write this program in C, regardless of how it is compiled? Please very much.
void main ()
        UART1_Init(9600);
        while (1)
                if(Button(&PORTA,2,1,1))
                UART1_Write("5501A3D2");
LeighM
Has thanked: 481 times
Been thanked: 699 times
Re: send string
Post by LeighM »
What is your target device and platform? Flowcode, Arduino, mikroC?
This will determine what function calls you can use. e.g. UART1_Init() and Button() etc.
It sounds like you are wanting help to edit a C program for mikroC, is that the case?
0101
Re: send string
Post by 0101 »
If possible for mikroC, if not, then in any C.
Thanks for the help.
0101
Re: send string
Post by 0101 »
Ok, if no one can help me with a program written in C, please then, if possible in Flowcode for PIC12F1822, because the 5.1 Flowcode version I have is limited. I'm interested the hex file.
0101
Re: send string
Post by 0101 »
Hello everybody,
Can anyone help me with a hex file for PIC12F1822, to send a string as we mentioned in the first post?
Re: send string
Can't help with Flowcode v5 but I could write you a quick v8 example you can use with the free 30-day trial.
0101
Re: send string
Post by 0101 »
Hi Mr. Ben,
Perfect, please help me.
Thanks in advance!
Re: send string
Here you go,
Demo.fcfx
(9.67 KiB) Downloaded 2251 times
Let us know how you get on.
0101
Re: send string
Post by 0101 »
Hi Mr. Ben,
Thank you very much, it's a great idea to try version 8, I was set on v.5 for Flowcode. Thanks again, I will download the free version, but I have to install a new version of the operating system. I'll keep you posted. :D :D :D :D :D
0101
Re: send string
Post by 0101 »
I can't install Flowcode version 8.2.2.
not be opened.png (12.81 KiB) Viewed 25717 times
Re: send string
Could your download got corrupted?
Try a different browser as I just downloaded 8.2.2 an all is ok.
This is what I downloaded:
Flowcode 8.2.2 installer.png (5.84 KiB) Viewed 25708 times
Is your file size the same?
Re: send string
Post by 0101 »
Hi Mr. Martin,
I downloaded again with Mozilla Firefox, the first time I downloaded with Opera. The size is the same. Download address:
https://www.flowcode.co.uk/flowcode/download/file/
Thanks a lot !
Flowcode 8.2.2.png (3.12 KiB) Viewed 25698 times
Re: send string
As File size looks correct:
V8 properties.png (38.18 KiB) Viewed 25689 times
What windows version are you running?
Re: send string
Post by 0101 »
I have Windows 8 version.
I downloaded version 8.2.2.15 from here: https://softdeluxe.com/Flowcode-144164/download/
How do I activate Flowcode for 30 days?
I forgot to mention that I installed it.
Windows 8.png (14.08 KiB) Viewed 25687 times
0101
Re: send string
Post by 0101 »
Hello everybody,
Re: send string
Just register for a Matrix account.
https://www.flowcode.co.uk/accounts/register/
Then activate your account by clicking the link on the email that is sent to you.
Then in Flowcode click on Help -> Manage Licenses -> 30 Day Unlock and use your account username and password.
You can also donload Flowcode direct from our website, I'm not sure about the softdeluxe version?
https://www.flowcode.co.uk/flowcode/download/?
0101
Re: send string
Post by 0101 »
Hi Mr. Ben,
Thanks a lot for the help, but I can't download the Flowcode v.8 license.
Sorry, the license is only valid for the product purchased, my mistake.
Re: send string
Post by 0101 »
Hello everybody,
I downloaded Flowcode from here: https://www.flowcode.co.uk/flowcode/download/?
after I created an account and after I logged in. At the first download I did not have an account created and
I was not logged in, maybe that was the reason why it did not install. I followed the unlock steps for use for
30 days, I got the activation of Flowcode v.8, but every time I launch Flowcode I have to approve the internet
connection, because the message says it is insecure and I have two options "Free and My Flowcode License ", if
I do not validate the free option, Flowcode closes, if I validate the free option, I cannot use the UART component.
I tried to get the unlock for use again for 30 days, but I have to validate the free option and when accessing Manage
Licenses only the My Flowcode License option remains. I can't use Flowcode 8, I'm sorry.
Successful activation.
I can't open Flowcode if I don't access the Free option.
Unsafe connection.
Unsafe connection.
0101
Re: send string
Post by 0101 »
Two more pictures,
The only option.
The only option.
I do not have access to the UART component.
Re: send string
hi,
You need to be logged in and running a 30 day trial to be able to use components like UART.
Re: send string
Post by 0101 »
Hello everybody,
I tried a new reinstallation, the same steps mentioned above and I received exactly the same messages posted above. I understand that for 30 days I have to test how Flowcode 8.2.2 works. and what's new in this version. In conclusion, you can't test Flowcode for 30 days, because you don't have access to all the components, more precisely you can use, 4 switches, 2 LEDs, display, numeric keypad, nothing else. It is not for 30 days, it is free and completely limited. In my post I was interested in using UART on 12F1822, more precisely obtaining a hex file.
Thanks a lot !
