send string
Re: send string
When you log in with Flowcode (Help, Manage licence)
You will need to enter the details that gives you access to the main Matrix tsl page.
That may be different to the forums details.
once logged in, you should get option for a 30 day trial, then all the components.
Option for free trial is not available if:
  • Flowcode not logged in.
  • 30 day trial elapsed.
  • Flowcode not got access to internet.
  • Use another account after 30 days expired on the first account.
I believe In the case of the last one, it will state to go to Matrix website to activate licence?
Been thanked: 1 time
Re: send string
Post by 0101 »
Hello everybody,
Unfortunately, the story repeats itself, the internet connection is ok, otherwise we do not create the account on Matrixtsl. The rest will be understood from the pictures. I think this way of authentication and activation of Flowcode 8.2.2. it is too restrictive. If you missed an internet connection to activate Flowcode you have to create another account, another account involves a different email address and a different phone number, well how many phones to buy ?
All the best !
0101
Re: send string
Post by 0101 »
Two more pictures
Re: send string
Flowcode not connected to server..png (6.98 KiB) Viewed 18746 times
Comes under
medelec35 wrote: ↑
Wed Aug 05, 2020 4:15 pm
More importantly the Marix TSL servers.
That is the issue
Your browser can connected to the internet but Flowcode can't
For some reason a firewall or antivirus is preventing this from happening?
For that reason I can't help you any further.
DavidA is the Matrix IT expert, maybe he can also help?
Re: send string
Post by 0101 »
Hi Mr. Martin,
I'm still trying, but I need to create another email address. In the Firewall I looked when I had problems and it seems ok, I will look carefully this time. I will have to create another account and another email address. Thank you very much for your help.
0101
Re: send string
Post by 0101 »
Hello everybody,
Firewall seems to be ok and still the connection problem persists. I don't have antivirus installed. I prepared the new e-mail address but I did not create an account on Matrixtsl because I receive the message that it is not connected and to check the internet connection. The internet connection is ok, I can enter Matrixtsl and any other site.
Re: send string
Post by 0101 »
The fourth picture.
Re: send string
Post by 0101 »
Hello everybody,
Please if anyone has version 8.2.2. Flowcode make me a program that sends a hexadecimal string with 12F1822, for example "5501A3D2" or any other string, using the UART component.
Thank you in advance !
0101
Re: send string
Post by 0101 »
Hello everybody,
Please, when you have time to make me a program in Flowcode v.8.2.2. compiled for 12F1822 to use the hex file.
mnf
Has thanked: 70 times
Been thanked: 440 times
Re: send string
Post by mnf »
Hi.
Not quite sure what you want to do - give us some more details. Do you want to just output a number to the UART?
What have you done so far?
Re: send string
Post by 0101 »
Hi Mr. Martin,
I want a PIC12F1822 to send a string and another PIC12F1822 to receive the string and retransmit it, using the UART component.
Thanks for the reply !
mnf
Re: send string
Post by mnf »
Have a look here viewtopic.php?p=102383#p102383 - might do what you are after?
Re: send string
Post by 0101 »
Hi all,
I saw the suggested link, but it's more complex for what I want. I ask for a simpler example, according to the attached diagram, a 12F1822 sends a string and another 12F1822 receives the string and resends it, using UART components. I want hex files compiled with Flowcode 8.2.2.
string send resend.png (16.22 KiB) Viewed 18641 times
Re: send string
Here you go...
DemoTx.fcfx
(10.9 KiB) Downloaded 610 times
DemoRx.fcfx
(12.01 KiB) Downloaded 584 times
0101
Re: send string
Post by 0101 »
Hi Mr. Ben,
Thank you very much for your help, but the first 12F1822 must send a hexadecimal string, "A1DB12E4", the second 12F1822 receives the hexadecimal string and resends it, but not to the first, it must be in the TX pin from the second 12F1822. Please if you can compile the two programs with v.8.2.2. to get the hex files, because I don't have anything to compile them with, I couldn't get the 30 days to test, my computer doesn't connect to the Matrixtsl server.
Re: send string
Are you behind a firewall or proxy?
If not then I don't know why the 30-day trial wouldn't be working for you?
I've asked David to have a look for you.
0101
Re: send string
Post by 0101 »
Hi Mr. Ben,
Thank you very much for your intervention.
0101
Re: send string
Post by 0101 »
Hello everyone
Here are two flowcharts, "send" and "receive", made on 16F877A, please teleport to 12F1822 and compile with version 8.2.2.
send string.fcf
(8.5 KiB) Downloaded 538 times
receive string.fcf
(10 KiB) Downloaded 501 times
Re: send string
Just a thought.
Within Allowed programs and features, What about Selecting Home/Work (Private) as well?
Also within Flowcode.
Select View, Global Options...
Then select the Applications tab
Make sure both Enables and Default Settings are selected.
Re: send string
Post by 0101 »
Hi Mr. Martin,
I made sure it was ok, see below.
con set.png (34.89 KiB) Viewed 18593 times
web access.png (29.16 KiB) Viewed 18593 times
Re: send string
I notice that the main thing that could be at fault is this.
I downloaded version 8.2.2.15 from here: https://softdeluxe.com/Flowcode-144164/download/
Please can you uninstall this version and download the version direct from our website from the link below. I wonder if the version you have installed has somehow been tampered with?
https://www.flowcode.co.uk/flowcode/download/
Normally it just works without having to mess with any settings so this is the only thing I can think of.
It would be interesting to see if the flowcodev8.exe file still bears our digital signature.
0101
Re: send string
Post by 0101 »
Hi Mr. Ben,
I uninstalled version 8.2.2.15 earlier and installed version 8.2.2. from your website. Look below.
signature 2.png (33.59 KiB) Viewed 18582 times
0101
Re: send string
Post by 0101 »
Another picture.
certificate 2.png (37.97 KiB) Viewed 18582 times
Re: send string
Aha ok so your using the official version now but that is still having problems. Very strange? Hopefully David is back in today. I'll ask him to have a look for you.
0101
Re: send string
Post by 0101 »
Hello everyone,
Please help me with two hex files for 12F1822, one for string sending and the other for string reception until the connection with the Matrixtsl server is resolved. Above are two flowcharts and the diagram with the two 12F1822.
