The lookup table doesn't seem to work with long (32 bit) ints.
Has a lookup table (32 bit unsigned) - and two values stored GetInt(0) (returns a ULONG) returns 64 which is the LSB of the first item stored. It obviously just returns a byte - but the docs imply if should return an int.
Lookup table 32 bit ints
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
Re: Lookup table 32 bit ints
Please try the attached, to go into C:\ProgramData\MatrixTSL\FlowcodeV8\Components
Leigh
Leigh
- lut.fcpx
- (46.56 KiB) Downloaded 222 times
mnf
- Has thanked: 70 times
- Been thanked: 440 times
Thanks - seems to work AOK.. I've tried 16/32 bit signed and unsigned and float and all seems good..
The only gotcha I can find - is because GetInt returns an unsigned long - retrieving a signed 16 bit value to a 32 bit signed variable the result doesn't get sign extended. (so -2345 will give 63191 as a result.) - so have to use the right 'size' variable for the result.
