Hi guys,
I'm using a HT1632C Led driver chip in a project. This chip is controled by a serial interface.
The chip interface uses: #CS, #RD, #WR and DATA (bidirectional).
For now i'm using the SPI bus to put data into the chip (#CS=custom, #WR=CLK and DATA=Mosi).
This works fine with my own custom code in a macro but i also like to read out the chips data. For this i need to control the #RD pin and read the DATA pin.
Is it possible to make a global interface driver using these four pins?
Patrick Schoon
Add Serial MCU interface (HT1632C)
Forum rules
Only feature requests will be considered here. General questions should not be posted in this forum.
patrick schoon
- Has thanked: 7 times
- Been thanked: 13 times
bercioiu
- Has thanked: 90 times
- Been thanked: 34 times
Re: Add Serial MCU interface (HT1632C)
Hi Patrick!
I've been struggling for a while to drive HT1632C ... Can you give me an example in Flow Code, to see how you managed to use it?
Thank you very much!
Puiu
Puiu
