I have the BL0080 and want to program a 12f1501, as the board does not have a 8-pin socket I have used the icsp onto some breadboard but keep getting this error when sending to the chip - Unknown chip type in data file
I have checked my connections and all seems fine - what am I doing wrong?
Ben
12f1501 - Unknown chip type in data file
Re: 12f1501 - Unknown chip type in data file
Sounds like not yet supported by mLoader.
Trying to find an updated list of mLoader supported devices.
Found this page 4.
Perhaps there is a more up to-date version somewhere?
Steve would know.
Do you have a programmer that does support 12F1501.
E.g PICkit 3 or 4?
Found this page 4.
Steve would know.
E.g PICkit 3 or 4?
Everything I have read says it does, I have the new Eblocks2
https://www.matrixtsl.com/webshop/e-blo ... ammer.html
I hope it does as I have just bought 40 chips for a load of upcoming projects and chip has been around ages, the datasheet I have for it is 2011
Ben
Ben
You could be correct but is there a document that specifically mentions pic12F1501 is supported by mLoader?
If so I will take back What i said.
Edit: Just searched mLoader for keyword of 12F and results are: That would also suggest not supported by mloader.
Does not mean not supported by the eblocks as hardware, just need external programmer.
Reason: Added information from 12F search within mLoader
