If you are not supplying a clock signal to the Timer 0 external clock Pin then the interrupt will never fire,in this case set the Timer clock to Internal Clock (Clock Source Property)
- P5.jpg (22.53 KiB) Viewed 2255 times
Set The property to Internal as shown below
- P6.jpg (19.23 KiB) Viewed 2255 times
