WS2812B Lights white at first then starts working normally
I am just making it Blink. I am including a small clip below
https://mega.nz/folder/tM1Hia6a#fHkC1LTFQDlfCk4_NxPPTw
WS2812B
Re: WS2812B
Can we please see your program, my guess is it's something there that is causing the white output.
Marko_2001
Re: WS2812B
Hi Benj,
Here it is, I know there is no need for the delays between, and in the first loop I changed to setAllLED's color
I was just experimenting trying to solve the issue.
- Flowcode1.fcfx
- (13.01 KiB) Downloaded 324 times
Re: WS2812B
Thanks for the code.
Maybe try a small delay (100ms) before calling the initialise function. Initialise does a refresh I beleive and if the chip isn't running at full speed when it does this then it may clock out incorrect data.
Marko_2001
Re: WS2812B
Hi Benj
I have put the delay as advised, also noticed there was a component update which I installed, restarted flowcode, and recompiled
but still the same problem.
Marko_2001
