MIAC CAN Interrupt
QMESAR
Has thanked: 384 times
Been thanked: 614 times
MIAC CAN Interrupt
Post by QMESAR »
Hi Team.
Can you please help me ,is there anyway that I can link the MCP2515 CAN controller INT pin to one of the IOC pins on the Micro ,
in a busy application polling the CAN bus results in a loss of messages,
I am prepared to do the HW change myself but with out a schematic it is Risky affair
LeighM
Has thanked: 481 times
Been thanked: 699 times
Re: MIAC CAN Interrupt
Post by LeighM »
Which version of MIAC are you using?
QMESAR
Post by QMESAR »
Hi Leigh,
Sorry it is MIAC dsPIC V3 or something
LeighM
Post by LeighM »
There are no spare inputs.
But you could link across to either (UART0 RX) Port E1, or (UART1 RX) Port E3
Assuming you don't require both UARTs
These are available if you remove the UART selection header link ...
QMESAR
Post by QMESAR »
Leigh
Thank you that helps a lot ,I do not need both UARTS only 1 for the RS485 ,
Thanks again
