Help with Mikromedia 3 Dspic33ep + Shield
RLOPES780
Been thanked: 3 times
Post by RLOPES780 »
I bought this kit and saw that it comes with the following features:
Full-color TFT displays
Display size 2.8 "
Resolution 320x240px
Graphic controller ILI9341
Resistive Touch Screen
Architecture dsPIC / PIC24 (16-bit)
DsPIC33EP512MU810 MCU
MCU speed 70 MIPS
Memory MCU 512 KB of Flash, 53248 bytes of RAM
Programming Preprogrammed with fast USB HID bootloader. Also features mikroProg for PIC, dsPIC and PIC32 connector.
Storage 8 Mbit Serial Flash, microSD card slot
Sound and Audio VS1053 MPEG audio decoder
Peripherals include USB connector, Accelerometer, Battery Charger
Expandability Two 1x26 headers, mikromedia standard pinout
Integration Mounting holes
Input Voltage 5V (via USB)
What is the ideal configuration of the Microcontroller, to run at 70 MIPS. Can you show me the configuration?
Grateful;
Ricardo.
Has thanked: 182 times
Been thanked: 179 times
Re: Help with Mikromedia 3 Dspic33ep + Shield
Hi Ricardo
I found your set:
https://www.mikroe.com/mikromedia-starter-kit-dspic33ep
and the DSP:
https://ww1.microchip.com/downloads/en/ ... 70616g.pdf
The board has a 8 Mhz OSCI . You can use this with the PPL.
