ESP32
rafaeltgross
ESP32
Post by rafaeltgross »
I'm trying to program my ESP32-WROOM but, unfortunately, is not working.
Here is my board
https://forum.fritzing.org/t/esp32s-hil ... plate/5357
The pins does not match the ones on FC9.
Can anyone please help me?
Rafael
LeighM
Has thanked: 481 times
Been thanked: 699 times
Re: ESP32
Post by LeighM »
Hi Rafael,
Even if the pin mapping on the board is different,
you should still be able to select IO via the GPIO/pin numbers,
e.g. GPIO6 is PORTA6
rafaeltgross
Re: ESP32
Hi LeighM,
Thanks for your reply, I will try.
When is PortB. Where I can find a better description about these Ports?
LeighM
Re: ESP32
Post by LeighM »
Each PORT represents 32 pins.
So PORTA 0 to 31 is GPIO0 to GPIO31
PORTB 0 is GPIO32 etc...
rafaeltgross
Re: ESP32
So here is my test report
the right side is working GIOP23 to GIOP15 (so from pin 23 to 37)
the left side GIOP13 to GIOP32 (from pin 7 to 15)
before I was testing all the non working pins such as GIOP-6, 7, 8, 9, 10, 11, 34, 35, 36, 39.
So is there any reason why these ports are not working?
Can I use UART0 ,1 and 2 in this board with FC9?
many thanks
Rafael
LeighM
Re: ESP32
Post by LeighM »
UART0 is best avoided as this is the debug channel.
Do you have another unit to test?
Re: ESP32
Hi, Rafael
I believe IO34 to IO39 are inputs only.
That can easily catch people out.
LeighM
Re: ESP32
Post by LeighM »
rafaeltgross
Re: ESP32
Hey,
Thanks for everything.
cheers dudes
Raf
Re: ESP32
You're welcome Leigh & Raf.
Good link you have posted, Leigh. :)
