Attempted an unsupported operation while configuring Interrupts
A forums to allow bugs and problems with Flowcode v7 to be reported and resolved.
George_B
Has thanked: 51 times
Been thanked: 19 times
Post by George_B »
I am facing a problem with Flowcode V7.
When i use the interrupt icon in the program and trying to configure the interrupt properties i get an error window like below.
After i select Ok on this window.. another message window pops ups like below.
Could you please advise for a possible fix? I had no problem with the program at all in the past.
I have used the last suggested patch release for the program as shown below.
Thanks in advance
George_B
Has thanked: 114 times
Been thanked: 422 times
Re: Attempted an unsupported operation while configuring Interrupts
Post by Steve »
Hi. Please post your project file and I'll investigate. Also, what target chip are you using?
George_B
Post by George_B »
Hi, thank you for your reply.
The device i am using is 18 F4680 .
Today i used my laptop to load the same project file into FC7 and it is working fine. I can not find the reason that is not working on my desktop!
Post by Steve »
I've tried to replicate the issue without success. You could perhaps try overriding the language (in Global Options) to English and see if that fixes the issue. Another thing to try is download the latest updates from viewtopic.php?f=63&t=19743.
If neither of the above work, then perhaps you need to uninstall and reinstall Flowcode.
George_B
Post by George_B »
Steve wrote: ↑
Mon Oct 11, 2021 4:37 pm
This did the job! Now works again fine.
Thanks for the support!
George
George_B
Post by George_B »
After i recently formatted my pc with windows7, i installed my licenced Flowcode7 and applied the updated version from this link:
I am getting this error again.
I have tried all the suggestions above(language override, re installation) and none of them is working!
Could you please suggest a possible solution?
Thanks in advance !
Best Regards
George
Post by Steve »
It sounds like there is a problem with the FCD definition file for that chip. The FCD file attached seems to work for me using V7.3.0.5.
The FCD file lives in the "\FCD\PIC" folder of the Flowcode v7 installation location. Can you please post your FCD file and I will compare to see if it is the same.
18F4680.fcdx
(25.86 KiB) Downloaded 279 times
