Compiler error xc32
r_teixeir
Has thanked: 24 times
Been thanked: 5 times
Compiler error xc32
Post by r_teixeir »
Hi, Im trying to compile a simple test program and I have this error. Can somebody please help.
Rod
Simple led test error.jpg (69.27 KiB) Viewed 16128 times
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: Compiler error xc32
Post by kersing »
Please go to the folder of your flowchart and look for the .msg file. Past the contents to a message. Your screenshot is illegible (for me at least).
― C.S. Lewis
r_teixeir
Post by r_teixeir »
Hi Kersing thanks for replying. Here is the attachment.
Rod
Teste_Leds.msg.txt
(2.29 KiB) Downloaded 220 times
Hi Rod,
It looks like the latest version of the PIC32 compiler may need to be licensed, or at least activated in some way before you can use it.
The toolchain we supply is not the latest but should work well.
If you need the latest toolchain then maybe when installing there are options on if you want a free or licensed version.
r_teixeir
Post by r_teixeir »
Hi Benj thanks for replying. I downgrade the version of installation and it worked nicely.
Rod
