Hi. Can anyone help me convert from V6 to V8? I just switched to V8 but my whole old project is in V6.
Thanks for your support!
Convert project from V6 to V8. Need help
georgecorbett
Last edited by georgecorbett on Tue Oct 18, 2022 10:11 am, edited 2 times in total.
Re: Convert project from V6 to V8. Need help
Hi George.
I can help you with that.
If you want to try yourself first, then the biggest difference is C code as different compilers were used.
This might help?
If you are still stuck then if you post or PM the the Flowchart, then I will convert it for you.
This might help?
