switch debounce
siliconchip
Has thanked: 101 times
Been thanked: 24 times
switch debounce
Post by siliconchip »
hi all,
my question concerns switch debounce when connecting a switch to a pic micros input, whats the best method for the PIC, ive seen circuits using the cmos 40106 schmitt trigger with a couple of resistors and a cap, or just a switch with a cap and resistors or is the software method better ??, i did read some where that pic micros dont like just a cap and resistors with a switch on their inputs ?? and prefer the schmitt approach id appreciate any comments thanks in advance
bob
Re: switch debounce
Hi Bob.
If you use the switch component, then that will have a debounce option within properties.
The reason for debounce is because the microcontroller can so fast a switch detection, it will count the times the switch contacts have vibrated when the intention was just to detect a single switch event.
The other way is to have an input, then a decision branch if the switch is detected.
Within the decision branch, have a delay that will cover the maximum bounce duration e.g 10 to 50ms
Both methods should work well.
siliconchip
Re: switch debounce
Hi Martin
as always thanks for the reply so it's safe to say that the software debounce is just as good as the hardware variants plus with the added bonus of a lower component count
Bob
Re: switch debounce
You're welcome.
The answer is yes.
I have never used external components for switch debounce. I have used both software methods for great reliability in my projects.
siliconchip
Re: switch debounce
Thanks Martin 👍👍
