Remap Function
Bruno
Been thanked: 21 times
Remap Function
Post by Bruno »
Hello at all
I usually use a macro to remap outputs of different types of sensors. I saw that a "Map function" component was created in FC9.
I want to share this macro and the assembled component, for everyone who still has FC8 like me.. It works with both Int and float variables
Suggestions for improvements are accepted
Remap_Component.fcfx
Macro
(9.98 KiB) Downloaded 254 times
Remapping.fcpx
Component
(1.65 KiB) Downloaded 242 times
Remap_Test.fcfx
Example
(10.88 KiB) Downloaded 226 times
Re: Remap Function
Hi Bruno.
Thank you for creating the Map component.
My suggestion would be to use a single Long for the calculations as just using ints will cause rollover to occur.
See here.
Credit to our VC member mnf for spotting the issue with the v9 version.
Bruno
Re: Remap Function
Post by Bruno »
Hi medelec
Thanks for your suggestion, I also had variable overflow problems,
in fact I used a Long variable, even though I wrote Int. :) :)
AbhijitR
Has thanked: 284 times
Been thanked: 80 times
Re: Remap Function
Post by AbhijitR »
Hello! Bruno
First of all many thanks for this post and for the component, to be honest I was struggling with the INT calculations because of the rollover issue but your Floating Variable in the component solved my problem. I do appreciate your thought for making the component for users who are not using V9 and V10 still.
As you mentioned in your post for suggestions, kindly excuse me to speak my mind, but I think your component will get complete by adding the CLAMPING function too in the Parameters, no doubt it is as per your convenience and time availability.
Once again thank you for this nice component.
Abhi
