I am using program that measures temerature in my room and it reports it on my home page, now i would like to get that temparature(variable) from my home page to my e blocks so it could do make necessery action based on temparature.
Best regards
How to get variable off internet
Re: How to get variable off internet
You have several options here to get the data from the PC to the system,
RS232 / Serial
USB
Ethernet (advanced)
What did you have in mind.
RS232 / Serial
USB
Ethernet (advanced)
Your best bet is to read through this if you want to use ethernet.
http://www.matrixmultimedia.com/Learnin ... ersion.pdf
You will probably have to communicate via a custom TCP or UDP packet so a bit of research may be required to complete the PC side of things.
