EasyPIC5 with FlowCode
JWalthall
Been thanked: 1 time
Post by JWalthall »
I have had FlowCode for some time but have not had the time to do much learning so I am really a Newbie to this software. I would like to use a Mikroelektronika EasyPIC5 development board with FlowCode. Has this been done by anyone and if so can you please walk me thru what I need to do to use this board to burn the chip. I know that I can save the file as a hex file and then burn using a JDM but I would really like to burn using the chip programmer on the PIC5 board. I will need a step by step proceedure as I really am new to this. Thanks to all in advance.
Re: EasyPIC5 with FlowCode
You will need to see which programming tools are available for the board via the Mikroelektronicas website. If the programming tool for the board has a command prompt mode then you can use the Flowcode's Chip -> Compiler options menu to assign the new programming software. This will allow for programming direct from Flowcode.
JWalthall
Post by JWalthall »
Thanks for the insite I have FlowCode up and running with my PIC5 board. It was just as simple as pointing FlowCode programmer to the PIC 5 software. Thanks again !!
