To day i work with a macro with 12 local variables.After i select all these 12,start simulator,"steep by steep",it works well >
I stopp simulator,modify my code and start simulator again i must select all these 12 local variables again!
I find if i select local variables the first time,flowcode must hold selection for these session ...... because it is a hard work
12 local variables for all new simulator start select again.
Regards Wolfgang
local variables
saschech@gmx.de
- Has thanked: 1 time
- Been thanked: 26 times
saschech@gmx.de
Re: local variables
Hallo Steve,Benj,Sean
Is these reaction for locale variables wanted?
Regards wolfgang
Regards wolfgang
Re: local variables
Hello Wolfgang
This has been fixed in V4.1 of Flowcode.
I have been able to add variables to the watch window, stop the program add more code and more variables and then restart the program to see the same variables in the watch window. You may still be using the Beta version of Flowcode 4.1 we made quite a few additions before the final release.
saschech@gmx.de
Re: local variables
Hello Benj
Please have a look into the sample for test.aus,test.aus1,test.aus2 and simulate ,i have the new version .
Regards Wolfgang
Regards Wolfgang
- (66.69 KiB) Downloaded 776 times
- test.fcf
- (4.5 KiB) Downloaded 251 times
Re: local variables
Hello Wolfgang
Yes ok this is the latest version. I see that the global variables in the watch window remain correctly but local variables are removed from the window.
Also I see what you mean now about the toolbar popping back to the top menu. This only happens if Flowcode is closed or a new instance of Flowcode is created.
