I planing to use a PIC18F4550 in a project were I can connect my PC to the PIC via the USB to download new programs as well as receive data.
My PC recognize that a new USB device is attached, but doesn't find any driver for communication.
Is it possible to modify the USB driver for the ECIO to work with the PIC18F4550?
Erik
USB conection to PIC18F4550
Re: USB conection to PIC18F4550
Hello Erik
What are you developing your USB program in? The driver you require will be specific to the type of device you are trying to create. Is there an example driver that you can use?
Hello Ben,
I am using Flowcode 4 to make my program with.
Just to try the communication I have used Joystick example program and changed the ECIO to my PIC.
I were able to download the program with the PIC programmer (EB006), but I don't know if the USB function is running as it should since I don't get any communication.
Brgds
Erik
Brgds
Erik
Erik
Hello Erik
Please post V4 questions into the V4 forum topic.
Have you changed the onboard crystal for a compatible value and have you set the configuration data correctly to correspond to your crystal.
http://www.matrixmultimedia.com/mmforum ... =26&t=6167
I have moved this topic to the V4 forum, Please use the Help -> Online resources link in Flowcode to gain access to the v4 forum topic.
If you like you can attach your program and I will have a look to see if there is anything out of place.
Hello Ben,
I have tried with the example file called "USB Slave Demo 3-Byte" and change the PIC to PIC18F4550. I did also the configuration as in the link you sent.
The computer now find and install the USB driver, but still I can not download or modify any program via the USB port. The only way is via the EB-006.
I have sent the example file that I have used. The crystal is 4MHz.
http://cid-915418450c964fe9.skydrive.li ... 3-Byte.fcf
Brgdrs
/Erik
Brgdrs
/Erik
Erik
kersing
- Has thanked: 553 times
- Been thanked: 1081 times
Erik,st9905 wrote:I have tried with the example file called "USB Slave Demo 3-Byte" and change the PIC to PIC18F4550. I did also the configuration as in the link you sent.
The example code does not contain a boot loader. If you want to be able to update programs in the 18F4550 you need to load a boot loader into the 18F4550. The ECIO contains a boot loader for this purpose. However, that boot loader is part of the ECIO offering and not available separately.
I am currently looking into creating a generic USB boot loader.
Best regards,
Jac
― C.S. Lewis
― C.S. Lewis
It seems there is a problem with the USB library with v4.0 and v4.1 of Flowcode. Please visit this FAQ page to download the latest up to date version of the USB library.
http://www.matrixmultimedia.com/support ... .php?t=553
I have updated the USB library, but still I can not connect.
In the complier option I have change to "boostc.pic18.flowcode.exe", but still no communication.
Do I have to make any other changes in the complier option?
/Erik
/Erik
Erik
Hello Erik
No you should not need to change any compiler or linker options the 16 gets replaced by 18 automatically when you compile to an 18F device.
One customer was having a similar problem but managed to get his 18F4455 working with the USB by autodetecting the device before assigning the configuration settings. You do this via the Chip -> Configuration window and then switching to the expert settings. They then compiled and programmed and their USB is working correctly.
This should also work for your 18F4550 as it is in the same device family.
