Hello All,
This might be a stupid question but how do I use the string variables?
Let me give you an example.
Let's say I have a string variable MSG, when you create this variable it is an array of size 20 (MSG[20]) max.
Now if I want to my string to be for ex. "Flowcode 4 rocks" (and later use that as output for an LCD), how do I make MSG="Flowcode 4 rocks"?
What happens if my text is longer than 20 characters?
Also, is there a way to add comments to variables when creating them in the Variables manager (e.g. LCD_OUT //This variable will be displayed on LCD)?
I'm not sure I explained this very well but if it doesn't make sense let me know and I'll try again.
D.
How to use a string variable?
Re: How to use a string variable?
Basically to create a string, Drag the string manipulation box on your flowchart.
Double click box after it had been dragged.
Click on 'Variables', then click 'Add New Variable'
Select 'String', then type your variable name, the default string size is 20 so if you want a smaller size e.g 10 then put 10 within square brackets straight after variable name e.g. MSG[10]
Message[4]
etc
Click on 'Use Variable'
Then use an equals sign followed by string value within speech marks. Finally you can add comments by using //
e.g
Message[15] = "Flowcode 4 is the best"//well until V5 is out
or you can add comments by using comment box (just below the C Box) on the left tool bar.
There is a lot you can do with strings. e.g just displaying first four characters or converting to integers etc.
While you can click on 'Variables', you can also click on 'Functions' for a full list of functions.
If you assign a string with a length of 5 instead of 15 using the above example, then Message string = "Flowc" all the rest will be ignored.
If you are going to add comments, best advice would be follow this:
http://www.matrixmultimedia.com/mmforum ... =29&t=6781
At lest then you would be able to see them!
Finally take a look at flowcode 4 examples. See:
http://www.matrixmultimedia.com/Flowcode3a-X.php
Scroll down to Flowcode 4 examples.
Also download other flowcharts form other flowcode users (especially Benj steve and sean) to give you a better idea on how to use flowcode. It will certainly pay off
Hope this helps
Message[4]
etc
e.g
Hope this helps
F22-Raptor
Thanks medelec,
I will have to try that tonight when I get home.
I've been looking at other examples and have been lurking on this forum for a while but I'm really new at FC so most likely I'll be asking some more stupid questions soon.
I really appreciate your quick reply.
D.
D.
