Sensor LM50BIM3 in Celsius
I'm about to fix temp gauge.
I wonder what to do in order to display in Celsius.
instead of the value is 0 to 1023
the ADC is working with
PIC16F690
Kristal 4MHz
temp sensor LM50BIM3
John
PIC16F690
Kristal 4MHz
John
Re: Sensor LM50BIM3 in Celsius
The 0-1023 ADC result is representive of Voltage on the analogue input pin. There should be a calculation that you can follow that will specify how to convert the voltage supplied from the sensor to a temperature reading in degrees C.
Hello John
Your in luck, this one looks quite simple.
According to the datasheet.
The LM50's output voltage is linearly proportional to Celsius (Centigrade) temperature (10 mV/DegreeC) and has a DC offset of a 500 mV.
So heres what to do in Flowcode.
Temp Result = INT Variable
Comp macro: Sample ADC
Comp macro: Temp Result = Read Value as INT
Calculation: Temp Result = Temp Result - 102
Calculation: Temp Result = Temp Result / 5
Hope this helps.
Hope this helps.
I'm not that good with maths... You can ask Steve :p
What about:
Calculation: Temp Result = Temp Result *50
Calculation: Temp Result = Temp Result / 102
Calculation: Temp Result = Temp Result - 50
Or
Temperature = ADC value as int * 50 / 102 - 50
So if ADC value as int = 153 = 0.75V then
Temperature = (153 *50)/102 - 50
= 25
Using another sample if ADC value as int = 358 = 1.75V then
Temperature = (358 *50)/102 - 50
= 125
Ben, bit odd my results don't agree. with yours:
(153 - 102)/5 = 10
Perhaps I'm missing something?
What about:
Or
= 25
= 125
(153 - 102)/5 = 10
Ben, not sure if I am correct or not. Please let me know If I have gone wrong in the calculations.
Thank you.
Thank you.
foppa
Just curios if you hardware is displaying correct temperature now?
No, it shows about 10 when the current temperature is 18.
Have not had time to test this further.
'll Try to do it tonight.
I have also another problem, it is that value is not fixed / stationary on my screen.
Oscillate up and down.
Do not know what to invent to this problem.
But I'm going and try your solution
Foppa
Foppa
You can place a delay that will slow down the rapid change, so you can read display. This may seem a daft question but. If change is too rapid, then is o/p connected to pin you have set up to read? If pin is floating then you will get allsorts of rapidly changing figures. Measure the o/p from your sensor, and see how much that changes. Does the LCD change at the same rate?
Also check your formula. If there is an error with formula, then a small change to i/p could cause a large change to calculated value.
When I created a flowchart with a temperature sensor, I measured the voltage on pin that's connected to sensor o/p, then did the maths to make sure correct temperature would be displayed.
If fomula used is: Temperature = ADC value as int * 50 / 102 - 50
What you could do is measure room temperature. Then transpose for ADC so you have:
ADC value as int = 51*(Temperature + 50)/25
So if room is 21 deg C then ADC value = 51 * (21+50)/25 = 144
Just confirm if all agrees.
hello medelec35
I tried this and it seems to show the right
"Temperature = ADC value as int * 50 / 102 - 50"
But the value of the display goes up and down.
It goes from 25 down to 17 and up to 25 again.
all the time.
I have insert the 4.7kohm for pullup.
I enclose my small test program.
Perhaps you have someone the idea of what I'm doing wrong.
Foppa
all the time.
Foppa
- Analog 690.fcf
- (7 KiB) Downloaded 400 times
Formula looks OK. Only thing I can think of is lack of supply decoupling capacitor can cause instability, whether you are using a voltage regulator or batteries. Just remembered. When I made my temperature sensor, I was using batteries for a power source. The instability threw me. Was sorted by using placing a 4u7F Electrolytic Cap between VDD and VSS. You should not require a pull-resistor.
When you measure voltage on pin 19 which you have got sensor connected to, is it stable at correct voltage for current temperature being measured?
Improved your Flowcode slightly.
Depending on LCD you have used, can also place a suitable degrees symbol next to the C
- Analog 690_1.fcf
- (7.5 KiB) Downloaded 394 times
What type of capacitor should I have.
And what value will it have.
Should it be connected in series with LM50BIM3.
I see that you have changed a bit in Coden.
Should be fun to try this tonight
Many questions now.
I thank you for all the help.
Foppa.
Many questions now.
Foppa.
What I have posted won’t stop the instability, that’s caused by your hardware. The program I posted just formats display slightly better and gives less of a flicker. It’s as broad as is long. Supply decoupling capacitors are just low value non-polarised capacitors connected across power supply e.g. 100nF Mica or cermic (RS 653-0210. for example). I have not seen your circuit, but take a look at 78L05 datasheet for capacitor values.
The 4u7F Capacitor I used is RS stock number 116-852P This is polarised, so connect +ve of cap to +5V of chip and –ve of cap to 0V of chip.
It would help if you posted your circuit diagram.
