It is caused by a small tolerance issue with some of the calculations within PPP which are exacerbated by recent changes to the hardware.
The "Board voltage is too low" warning message can safely be ignored. If it gets too annoying, there is a work-around as follows:
This unnecessary message can be removed by replacing the following line in the "PPP_SCRIPT_DATA.CFG" file...
VMIN_MULTI=195Code: Select all
VMIN_MULTI=150
