problem with avr waituntil
ikke
Post by ikke »
I am trying to toggle an output with a simple pushbutton. For 1 input/output the switchmacro works, but for the second one it just passes the macro.Or is there a better solution?
Thanks.
toggle.fcf_avr
(6.5 KiB) Downloaded 283 times
Sean
Has thanked: 6 times
Been thanked: 44 times
Re: problem with avr waituntil
Post by Sean »
Hello Ikke,
The only problem with the program is the parameters being used in the WaitUntil macros.
The WhichSwitch(Byte) parameter refers to the position of the monitored switch within the port byte (0 to 7). This can be a calculated value to provide flexibility, but your program requires the constant values 0 and 1 in branches for the corresponding inputs.
Don't know if this will help.
This is how I controlled o/p that is toggled each time i/p goes high. It does not wait for a switch to be pressed before carrying on, program is constantly looping so other functions can be performed. While switch is pressed, program doe not continue until switch is released, to avoid rapid nuisance toggling .
(78.67 KiB) Downloaded 930 times
Note: Using var = var XOR 0b00000001 will also toggle.
