I have a brand new HP488 V3 and Flowcode V4. My program compiles fine but when it tries to send to the programmer I get a USB cable not connected. When I plug in or remove the cable I can see it come and go in device manager. Driver looks good and the amber light on the board turns on and off as cable is connected or removed. I installed PPP before plugging in the HP488, so the driver was loaded at that time. I am running out of ideas. Using Windows Vista.
Dale
HP488 USB cable not connected
Re: HP488 USB cable not connected
Hello Dale
This FAQ should help you to get up and running.
http://www.matrixmultimedia.com/support ... .php?t=510
Let me know how you get on.
I must have went through the FAQ's too quickly and I missed that one. Followed it step by step and I can now program to the device.
Thank you very much for the quick reply and the correct fix to the problem.
Dale
Dale
