Thermometer / Thermostat problems with display
For C and ASSEMBLY users to post questions and code snippets for programming in C and ASSEMBLY. And for any other C or ASM course related questions.
cobra1
Has thanked: 3 times
Been thanked: 3 times
Post by cobra1 »
Hi Guys
I have been playing with Flowcode 4 to build a thermostat,
so far i have the ADC input sorted and i have converted the INT value to a temperature value, and i can display this on the lcd
Problem is i want this to be set with a 0.5f resolution so the temperature should read say 87.5f or 90.0 f
this is the part i am struggling on, can anyone help.
would anyone happen to have done this sort of thing before??
Re: Thermometer / Thermostat problems with display
How are you doing your ADC to temparature conversion? Is it via a lookup table or a real time calculation? If it is a calculation then maybe you can simply store the result in a float variable. Then convert the float to a string and send the string to the LCD.
