Charging target chip - as default ??
How can I change target chip so it starts every new project with this new target chip ?
Best regards
KSor, Denmark
KSor, Denmark
Re: Charging target chip - as default ??
You can create a blank template file using the chip of your choice and even assign the configuration if you like so you dont have to keep doing this.
Then when you want to make a new project open the template file and then use the "File -> Save As" menu to rename the file and save it in alternative location.
Oh yeah, that's a possibility = one project as source for the next.
I would be nice to have the REAL template possibility.
Best regards
KSor, Denmark
KSor, Denmark
