I am on a very steep learning curve here, and i am look for a bit of help this my first time using pic micro's.
I am having trouble getting ANY chip/software to run. I have tried all the normal suggestions. Clock Ect,
and in all the setup configs i have tried i have only got the Low voltage enabled. I have now been play with this for over a week
Here is what i am Doing.
As a test i have just done a simple code with a LED on one out put Flashing on and off ever 3 sec. And another file with a switch on one input and a LED on the other.
I have set all the Clock speeds in the options and have it set in HS in both flowcode chip settings a PPP. but when i load it in the chip does nothing. I have tried to load it via flowcode and via PPP.
I have tried to run the chip in the EB007 v7 board and on the board i have had made but i am still not getting any where,
I have also tried to run the chip in RC mode and in XTAL mode and am still not getting much luck.
i have also found the only way i can program the a chip on the EB007 is if i have the board set to RC mode, these are the chips i have tried, 16f877, and 18f458.
Any help would be very appreciated.
Tristan
