GPS GROUND SPEED
wayne millard
Has thanked: 7 times
Been thanked: 12 times
GPS GROUND SPEED
Post by wayne millard »
Hi Team,
Can you please look at my code and see why ground speed in mph will not work.
Wayne :P
GPS Time and Date position.fcf
(16.5 KiB) Downloaded 322 times
Re: GPS GROUND SPEED
Hi Wayne,
I have had a quick look at your program and the reason the code is not working correctly is due to things like this.
mph = ground_speed/0.44704
This would instead have to use the floating point functions.
float = fdiv(ground_speed, 0.044704)
If your ground speed variable in an integer or a byte then you will first have to convert it to a float.
fgnd_sp = int2float(ground_speed)
float = fdiv(fgnd_sp, 0.044704)
The float functions are available from the functions button in the calculation icon.
There is lots of information on the forums regarding these functions.
wayne millard
Hi Benj,
Thanks for the help can you show me a example of how to do this because im lost.
Thanks,
Wayne :P
Hi Wayne,
This program should now compile and run correctly on the hardware.
Let me know how you get on.
(16.52 KiB) Downloaded 335 times
wayne millard
Hi Benj,
Thanks for the help but i get a error when i compile to hex.
wayne :P
Hello Wayne,
The error is related to this line of C code near the start of your program.
float_detect_tininess = long;
This should instead look like this.
float_detect_tininess = 1; //Detect tininess before divide
or
float_detect_tininess = 0; //Detect tininess after divide
wayne millard
Thanks Benj
