If in an existing macro in which already parameters are being used, new parameters are inserted, then an error (see fig.1) can occur when the inserted parameters are not adjusted at the macro properties. If then by accident is chosen for “continue” the next (see fig.2) appears.
At this point the program stays (see fig.2) and it is necessary to end the program with CTRL –ALT-DEL. Is this the intention? Run the attached program.
Problem Macro parameters
- testMacroFault.fcf
- (9 KiB) Downloaded 337 times
- Pictures
- Warning.JPG (31.88 KiB) Viewed 3993 times
Taurus
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: Problem Macro parameters
This issue is certainly not by design. The problem occurs when a "global" variable has been removed.
I'll look at sorting this out in a future release of Flowcode.
Hello Taurus.
I know it's not ideal, until there is a fix:
If you have the mouse over the stop icon, and press enter key whist simultaneously clicking on the stop icon, there will be a point in which the simulations ends.
