Receive RS232 string
Good morning !!
I'd like to receive a string from RS232, but I don't understand what kind of parameters I've to put in the RS232 routine
Example,
If I receive the string "COMPTEUR" from RS232, i send the value of a variable by RS232
Thanks you for your help
Example,
Adrien DG
Adrien DG
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: Receive RS232 string
You should use the "ReceiveRS232String" macro of the RS232 component. There should be some examples of this in the collection of Flowcode examples on the Flowcode CD.
I come back to you for my problem of RS232 receive string
I receive a string for example : " TEST "
If the string I receive is "TEST", I send a value, for example 10000
else I send an ERROR message.
I've used the compare() fonction in string manipulation block, but that don't runs...
Could you explain me how can I do it ?
Thant you !!!
Bye
Thant you !!!
Bye
Adrien DG
Adrien DG
Hello Adrien,
The string manipulation compare function returns a 0 when the strings match. Could this be the problem. I assure you it does work
Hello BenJ,
Yes I've seen a French Manual about flowcode, and I saw in it the use of this function
Look at my example,
If I send a "A", and I compare with a "A", I always receive a False
For sure I don't have understood one thing.
Look at my example,
- TEST RS232 - TEST RECEPTION.fcf
- (7.5 KiB) Downloaded 316 times
Adrien DG
Adrien DG
It might be worth collecting the length of the string and the contents of the string and echoing these values back also with the RS232 on a Error. This will show you what the microcontroller is seeing as received.
Other then this you can also check single characters from the string one by one using decision icons.
EG
RECEPTION[0] = 'A'
EG
RECEPTION[0] = 'A'
Hello BenJ,
thank you, that runs very well,
but now, I've another question ...
How can I program an Interrupt on the Rx pin ? Using the RXINT ??
Thank you in advance
Adrien DG
Adrien DG
Attached is an interrupt example of your earlier program.
You just need to ensure you use the dummy read component macro to enable the UART receive functionality before the interrupt will start working.
- (8 KiB) Downloaded 438 times
jgu1
- Has thanked: 1135 times
- Been thanked: 299 times
Hi!
I have follow this line. I have a question, What is the "11,11" in the Component Macro under variable?
Thank´s
Regard Jørgen
Thank´s
Regard Jørgen
Hello Jorgen.
The 11, 11 are values that are passed to the component macro call as parameters.
Looking at the help file for the component will explain the parameters meaning and role in the function.
The first is the number of iterations to wait before returning a no data received value. This is not needed as we are using the interrupt so you could change this to 1 if you like.
The second is the number of bytes to try and receive into the string variable before a timeout occurs.
