After installation C for AVR on Windows 7 64bit and want to start de C course i get the following message;
"Serial number not found or incorrect, please check your install of C4AVRs course"
Please can you help me to find a solution to start the C Course without problems
Kind regards
Huib
C for AVR install problem in Windows 7 64bit
Huib Koppers
- Been thanked: 1 time
- DavidA
- Has thanked: 58 times
- Been thanked: 258 times
Re: C for AVR install problem in Windows 7 64bit
Hi there,
http://www.matrixmultimedia.com/support ... f=10&t=588
Should help you out from the FAQ's its a fix to get the C course working on 64 bit machines.
Huib Koppers
Hi David,
Thanks for the reply and your patch has solved the install problem, but now i have another kind of problem that i can't see some visual applet which belongs to each coarse chapters which has to do with Java installed components.
For some visual items i got the message;
"No Java 2 SDK, Standard Edition v 1.4.2 support for APPLET!!"
This version of Java is installed on my system and stil got this message
I think the java components within de C4AVR CD are for XP environments which i do not have.
My Windows version is Windows 7 Pro 64bit.
How can I solve the Java problem so I can see the visual items which belongs to each coarse chapter ?
kind regards
Huib
kind regards
Huib
