I have pull-up on my C port. When i want to simul, default read is "0". Is it possible to change this. If not, could you add this in future version.
Thanx
Pull up
Re: Pull up
Hello Frank,
You could always add a single switch or switch bank to the port you wish to simulate the pullup on. Next change the switch type property to toggle and then start the simulation and set the switch. Your pull up will now be simulated correctly.
Frank123
- Has thanked: 1 time
Re: Pull up
No, my switches are in a keyboard, so I need to change the state of lines and columns and having a pull-up or pull down on the rows or columns.You could always add a single switch or switch bank to the port you wish to simulate the pullup on. Next change the switch type property to toggle and then start the simulation and set the switch. Your pull up will now be simulated correctly.
Frank
Electronics teacher
Electronics teacher
