Camera Component
kunibabina
Camera Component
I have an idea of developing camera component and interfacing to PIC using serial and USB. Example applications are object tracking. storing the image of unknown person etc. I request Matrix Multimedia to analyze the possibility on the same.
Re: Camera Component
I have been on the lookout for a good workable camera module for some time. I know this can be done however making it a reality actually prooves very difficult. The last module I found was a camera on sparkfun that looked great. The only problem is that there is no datasheet and no example code which is a bit of a nightmare to get working and then to support.
Therefore if anyone knows of a good module to use then please by all means let me know. Im not saying Matrix will definatley take it on but as you say there are a lot of potential applications that are screaming out for a camera.
As a side note if anyone knows where to get an IR camera from a WII handset then this would also make a great addon to an application. eg supplier and datasheet for the sensor, source of WII handsets doesn't really do it for you.
wayne millard
- Has thanked: 7 times
- Been thanked: 12 times
HI there is a project doing this in Elektor mag in september iss.
Here is a data sheet on the camera.
- 150001-da-01-en-S_W_KAMERA_MODUL_1.pdf
- (79.29 KiB) Downloaded 471 times
kunibabina
Also please check the following links :
http://www.alibaba.com/product-free/114 ... amera.html
http://www.gsm-modem.de/cmos_camera.html
http://www.coolcomponents.co.uk/catalog ... cts_id=370
- UART Camera SPE-English.pdf
- RS232 Cam Datasheet
- (59.89 KiB) Downloaded 448 times
Great thanks for the posts.
I will have a read on these and see if I can find anything workable.
