As the Backplane is metal should one use stand off's to avoid shorts?
Please remind me of the spacing and hole diameter.
I tried downloading the pdf file, but the link was broken.
BackPlane.
Re: BackPlane.
The E-blocks boards should come complete with rubber feet so there should be no chance of shorts against the metal backplane.
The hole spacing is on a 20mm pitch.
I'll see if I can remedy the datasheet link for the backplane.
KeithSloan
- Been thanked: 1 time
Re: BackPlane.
Out of Interest how thick is the backplane BP232?
The datasheet link still appears to be broken.
Re: BackPlane.
Looks like the backplane thickness is about 1.5 - 1.6mm. Ill send a request to the Marketing team to get the data sheet sorted.
