BEST BENJ
THANKS FOR YOUR INFO ....
BUT I STILL GET THE ERROR MESSAGE....
I SEND YOU MY PROGRAM TO HAVE A LOOK
THANKS IN ADVANCE
PUTS JOHAN
STORING VARIABLE IN FLASH 18F4455
- HAAGSCHAARLEVEL4tryout.fcf
- (31.08 KiB) Downloaded 317 times
Re: STORING VARIABLE IN FLASH 18F4455
I moved your post as it was a Flowcode related question. Please will you post the file into your existing topic rather then simply creating new topics.
If you need access to the Flowcode section then details of how to do this are available from here.
http://www.matrixmultimedia.com/support ... 5ef8438485
Benj wrote:Hello,
BEST BENJ
I can understand that it is looking for you as a new topic but this is still the same topic that i am trying to let it work
all the topics of the last 3 days that i have put on the user forum are about the same problem: how can i store a variable
into the memory of a pic 18f4455 so that after a power off of the chip 18f4455 i still can get only 2 variables of the last executed program. thats all
sorry that i interrupted you with questions that are not explicitly for your division.
what is not so clear for me is also the working of the user forum.when i do a reply to somebody (not private reply ) is it then not visible to the complete forum?
i hope you can understand that i am new on this forum and also in programming flowcode.
puts johan
engineer electronics
puts johan
