gLCD in Macro Issue
swatzy
Has thanked: 2 times
gLCD in Macro Issue
Post by swatzy »
Hi all,
I'm have a EB058/057 gLCD display, all set up and running using a PIC16F877A all works fine when I call the the commands in the main program. However when I move these calls into a Macro the last print command scrolls and overwrites itself. I'm using Flowcode4 with PIC_gLCD.c version 300410 as instructed from this forum.
Any clues??
swatzy
Jan Lichtenbelt
Has thanked: 128 times
Been thanked: 264 times
Re: gLCD in Macro Issue
Post by Jan Lichtenbelt »
A stack overflow?
swatzy
Post by swatzy »
It feels something like that,
I guess the big question is Why does me calling it as a macro cause this sort of error.
Jan Lichtenbelt
Put your flowcode file as attachment. That makes is easier to help you.
The 16F877 has only around 8 layers of hardware stack. Each jump to a macro or interrupt routine will consume one layer of the stack.
This topic details how to implement the BoostC software stack.
http://www.matrixmultimedia.com/mmforum ... ack#p19591
I will look into the code to see if I can spot why this is causing stack errors when it is running inside a macro.
swatzy
Post by swatzy »
Here's the sourcecode. Thanks for replies so far.
testglcd2.fcf
glcd call macro
(10.5 KiB) Downloaded 384 times
swatzy
Post by swatzy »
It was indeed the stack, added -swcs 6 2 to the linker parameters in the compiler options and it all goes. I think I'll need to use an 18 series PIC tho'
Thanks for help
