Making a 4x16 LCD from two 2x16 LCDs
Spanish_dude
Has thanked: 63 times
Been thanked: 102 times
Post by Spanish_dude »
Is it possible to make a 4x16 LCD screen from two 2x16 LCD screens ??
I have two 2x16 E-Blocks and though about making it a 4x16 LCD.
Rgds,
Nicolas Lopez F.
Re: Making a 4x16 LCD from two 2x16 LCDs
Yes this is possible though you will still need to use two LCD components in Flowcode.
You may even be able to pair up the data lines so that both LCDs run off the same 4 data lines you may even get away with commoning the RS line too. The E data pin will have to be unique for each display.
Spanish_dude
Benj wrote:Hello,
Hmmm...
I wanted to use one LCD component for that, but I forgot about the E pin.
So that's not possible unless I use 2 LCD comp.
Thanks Benj.
(Btw, have you received the gLCD E-Block ?)
Rgds,
Nicolas Lopez F.
Spanish_dude wrote:
Hmmm...
That's correct.
A similar thing was done here:
http://www.matrixmultimedia.com/mmforum ... =29&t=7804
Yes I have received the E-block and we are sending out a replacement for you. Putting pressure on one side of the display made it function correctly so I think the ribbon cable to the display must have become slightly damaged.
Spanish_dude
Yeah :mrgreen:
Thanks Benj. :)
singhdeol
Has thanked: 6 times
Been thanked: 2 times
Post by singhdeol »
i have 2x16 LCD laying around i might give that a shot as well, do any body got a circuit diagram for it.
Dan81
Been thanked: 60 times
Post by Dan81 »
hello singhdeol
you can do something like this
Daniel
PS think to connect VCC VDD GND and R/W
