How to print byte as binary string to gLCD?
Frequnator
Post by Frequnator »
Hi!
I have studied how to program with flowcode couple months now. I have 2 questions and I cannot find answers...
I have tried to find answer how to print i.e. number "2" (byte variable) as binary string like "00000010". I can change numbers to hex and print those to LCD just fine but I don't know how to print binary strings.
Case is this: I try to send 8-bit information via zigbee from end-node to coordinator and I would like to see that information on coordinators gLCD (like "1001011") but when I print that information to gLCD flowcode converts automatically that binary information to a number. I collect that "binary information" with 8-button switch board and send that information with zigbee send_char -macro. On coordinator I receive that information with zigbee receive_char and print that out to gLCD. How can I convert that character to binary string and print that 8-bit sting out?
Other problem is how to convert temperature infomation (byte 0-255 or int 0-1024) to normal understandable celcius float number. I have not yet tried to calibrate my temperature sensor, if I measure readings with boiling water (+100C) and result is i.e 223 (byte 0-255), how can I transfer that byte to understandable 100.0 like with normal digital thermometers?
I'm using Flowcode V4.2, E-Blocks with PIC16F877A and compatible e-blocks hardware. I read temperature information with e-blocks sensor board analog input.
Thank you all for answers!
Re: How to print byte as binary string to gLCD?
To print a byte out as a binary number you will have to create a little loop to do the following.
while loop with a count of 8 in the properties.
calculation x = byte & 0x01
if x
yes: print a '1'
no: print a '0'
calculation byte = byte >> 1
end while
Regarding reading the thermistor or temperature sensor there are example of how to do this already available from the forum.
Frequnator
Thank you very much! I got it to work!
I will search answers from this forum about that temperature probe. :)
darkmagic35
Has thanked: 2 times
Post by darkmagic35 »
Hello Benj,
I have 8 sources which can be TRUE (1) or FALSE (0), I save this 8 values to a string (test[8]) and I need to get a byte variable.
Can you give me examle how to convert this string (8 chars) to a byte? (1010 0001 -> 0xA1)
Thank you for your answers.
Spanish_dude
Has thanked: 63 times
Been thanked: 102 times
Post by Spanish_dude »
Hey darkmagic35,
There are two ways to do this.
The first one is setting "test[0]" as MSB (Most Significant Bit) and "test[7]" as LSB :
char i;
char byte = 0;
for (i = 0; i < 8; i++)
    byte = ((byte << 1) | (test[i] != 0))
The second method is setting "test[0]" as LSB and "test[7]" as MSB :
char i;
char byte = 0;
for (i = 7; i >= 0; i--)
darkmagic35
Thank you for your answear.
I tried to rewrite this code to flowcode but I wasn't successful. (I copy your C code to flowcode and modife variables and than I try to do this with flowcode's graphics components).
Can you give me please an example of one method directly in Flowcode?
Spanish_dude
darkmagic35 wrote:Can you give me please an example of one method directly in Flowcode?
Sure, here you go.
ConvertStringToByte sets test[0] as MSB and ConvertStringToByte2 sets test[7] as MSB.
Rgds,
Nicolas L. F.
EDIT:
- Forgot to add what's written in bold.
Flowcode1.fcf
(6.5 KiB) Downloaded 720 times
Jacob1
Has thanked: 7 times
Been thanked: 6 times
Post by Jacob1 »
Benj wrote:Hello
if x
yes: print a '1'
no: print a '0'
end while
I was wondering if you could explain what byte represents from this info? Do I need to create a variable?
As I am trying to create the loop and unsure of what icons to use. Do I need any outputs? If you have this loop on file that would be really useful,
I am trying to create a program which when a switch is pressed it shows the binary number on the LCD and lights up the corresponding LED. If you know how to do this or can give me a example that would be great,
Hi Jacob1,
Can you see if attached flowchart works for you?
If it does help, I can take you though how it works if you get stuck
Switch in Binary.fcfx
(14.23 KiB) Downloaded 414 times
Jacob1
Post by Jacob1 »
Hi Medlec,
Thanks for taking the time to complete a example!
However, I think that program is a bit different to the example you have given me. I am following a micro controller booklet, which gives a broad brief about what to do for each program. I think the program wants the binary number as in the 8 bit, such as 0000 0001. So as each switch is pressed, the 1 will move across. The program also asks for this "binary number" to be multiplied by 100, and for the LCD to show this on the next line
I have attached the program instructions below, and I would appreciate it if you could have a look at this.
Thanks for your help
Jacob
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
Is this homework/assignment for a computer course?
― C.S. Lewis
Jacob1
Post by Jacob1 »
This is a booklet which we follow for my college course, it is not homework or an assignment. As the course is a new spec, this is what we follow for lessons as we have nothing else! The programs can be completed at home in our free time. Our teacher works from this as well but is also very new to this.
Hope that makes sense
