Example:
CASE 1:
- Send 3 bytes (Tx start/Sendbyte/Sendbyte/Sendbyte/Tx end)
Wait 500 ms
Repeat forever
CASE 2:
- Send 3 bytes
Wait 100 ms
Repeat forever
I use TCP mode. EB023 is server, computer is client.
Can you explain this?
I can send you an example program which show the problem.
I use the following config:
EB006+18F4520 (same with 18f2680 or 16f887)
EB023
Direct connection to a computer with RJ45 CAT 5 cross-over cable (tested with the local network to)
Netstuff program as client (java program tested too)
wireshark for sniffing
